OTAP set up and initial programming
ictrcm
Sinai
Good afternoon we have just installed a mototrbo linked capacity plus system and in the process of deploying XPR7550/7350/5550 code plugs are deployed and successfully tested. However we are having trouble running OTAP as although the job ( change in code plug) is succesful. It.It seems to hang and indicates it waiting and when i look at job queue it sees nothing. I suspect the job isn't going out we are using a radio and not the repeater to propagate the changes.Does anyone have a full process to set up an OTAP connection from scratch?
Firebuff880
Boynton Beach, FL
You should be able to do this. The radio you are using as the donor radio must be in control station mode as a data gateway. Although for an LCP I have only done this with the wireline MNIS/DDMS gateway server. Look at this site you may find some answers. DJ0WH
Firebuff880
Boynton Beach, FL
abnrto
GA
Your problem is could be how you have the job processor set up. In the CPS path have you got it going to the trbo cps or to the cruncher? I have seen it used both ways. Send me a private message with your email and i will help you out.
ictrcm
Sinai
Do you know what i need to tick/ un-tick to setup the XPR5550 PROFILE so its defined as a control station on the CPS in linked capacity plus system?
abnrto
GA
I never change anything. That way a can just grab any radio to do OTAP. As long as you have the OTAP key in every radio.
Sent from my SM-G920V using Tapatalk
Firebuff880
Boynton Beach, FL
Your location say's Sinai -- So I assume you have EMEA software ? and while you said XPR-5550 since that's a NA radio you are probably using a DP something correct ?
As Abnrto pointed out you need to have the target radio authorized for OTAP -
Then the radio must be a Data Control Station -- Requires numerous settings in that radios Code plug - But they document it fairly well in the System Planning Guide and Radio Manager DP notes.
abnrto
GA
I dont use any data channels. I do it all over the voice channels. System Planner is good but here is a website that will help you out. Over The Air Programming (OTAP) Part 1 | DJ0WH Also, if you look at the cps that you download or the cd it will have a folder called documentation. It will have the pdf's that you will need. There is a radio management tutorial there also.
