Ottawa MTO
Jason_wyler
Has Left The Building
I’m thinking of listening to the Ottawa MTO since it's snowing. I'm thinking they will be busy, it should be active today.
I have Bell FleetNet program in as Conventional and I have OPP comms in and EMS but I do not hear the snow plows. I have the Kinburn tower programmed in.
I'm thinking I need to have it as a trunk system to hear snow plows.
gary123
The MOT will be analog. If you have the voice freq programmed in for your local site and are hearing EMS you will also hear MTO if they are active on the site.
Jason_wyler
I haven't heard plows yet so should I program all Ottawa sites ??
59296c0A2 BLACK2 BLACKPublic Works
382569570A2 BLUE2 BLUEPublic Works
3857696b0A2 BROWN2 BROWNPublic Works
384969660A2 EMRG RESP2 Emergency ResponsePublic Works
386569700A2 ALEX2 Point AlexanderPublic Works
3888097e0A2 OTTAWA 417417 Ottawa PatrolPublic Works
3832095b0A2 BANCROFT DISTBancroft DistrictPublic Works
3833695c0A2 BANCROFT OPSBancroft OperationsPublic Works
387689770A2 BRITTBrittPublic Works
3811294e0A2 CARLTONPLACECarleton PlacePublic Works
387049730A2 DORSETDorsetPublic Works
387369750A2 DUNCHURCHDunchurchPublic Works
3883297b0A2 ELMSDALEEmsdalePublic Works
3881697a0A2 FARLEYFarleyPublic Works
3836895e0A2 FRASERVILLEFraservillePublic Works
384009600A2 GRAFTONGraftonPublic Works
389289810A2 GRAVENHURSTGravenhurstPublic Works
3812894f0A2 HALEY STATIONHaley StationPublic Works
386889720A2 HUNTSVILLEHuntsvillePublic Works
381449500A2 KANATA WKanata - Hwy 416/417 West EndPublic Works
382729580A2 GREENLeeds/GrenvillePublic Works
387209740A2 MACTIERMactierPublic Works
384329620A2 MADOCMadocPublic Works
384649640A2 MARYSVILLEMarysville
@gary123 Can you create a plow file for me on Freescan?
Noseybody
Eastern Ontario Canada
I have been hearing road conditions every now and then on a frequency on what I have labeled as MOH. I just thought it was them, a supervisor or something, until yesterday at the end he said I have 6 plows on the road.
It is on my BC125AT I pick it up so can't replay to see which one frequency :( Will try and pay more attention.
I am along the 401, South Dundas ON.
mmisk
Ottawa Canada
I fired up Unitrunker and I just realized it is not switching to the voice frequency for analog calls,
Digital voice call are working fine though. this has never happened before.
I might try reverting to a previous version.
mmisk
Ottawa Canada
Thanks, I am on .20 and will download .22 now. Can't find a .22, so I downloaded .21 and installed.
Still no analog voice. Will check my laptop install shortly.
Aviator747
Cornwall, ON
I will look when I get home. I'm pretty sure .22 is the newest unless it was pulled. Analog was fine for me last night, at least off of the Cornwall tower.
mmisk
Ottawa Canada
Well, UT worked fine on my laptop.
Fresh install of UT on desktop computer solved the issue.
I renamed the UT files and data folder on desktop computer to save data, and allow UT to see this as a fresh install.
Installed .21 and it is functioning fine now.
gary123
It is always good to read posts where the poster supplies the solution to the problem. This helps anyone having a similar or the same issue and reading the thread. Good work mmisk.
gary123
it looks like 21 and 22 are tweaks to the GUI and import export functions. Unitrinker does a great job on logging although the initial population of TG aliases and radio alias takes a bit of time but once done Unitrunker gives a great overview of the systems being monitored.
