overheating scanner BCD436hp
kevincl
Hello
my BCD436hp scanner overheats at the keyboard and the battery at the back I installed a new Energizer 1300mAh rechargeable battery I had the Illegal Voltage error and my sound no longer works on my radio what to do?
Before I had Ladda Ikea 2450mAh batteries
Thank you
n1chu
Farmington, Connecticut
What happens when you run it from the wall wart? Do you have audio? But any time there is a heat issue like you describe its time to go in for repair.
kevincl
I can't plug it into the wall without battery,
when I put the battery charge already it says that my batteries are discharged and I connect it and it does the same.
And for the sound there is nothing just a little background noise
n1chu
Ok then. It’s time to call Uniden repair. They charge a flat rate of $80 to repair and an additional $10 for shipping it back to you.
MisterLongwire
Amateur radio operator/QC tech for radio mfr.
San Marcos,Escondido, CA.
Isay something is going on or something that happened you did not mention. You sure you are using AA nimh or nicad, and not lithium batts. Lithium batts are more voltage which will give you the "llegal voltage" warning.
tvengr
Well Known Member
Baltimore County, MD
I don't know why you would use a 1300 mah battery. Every Energizer rechargeable I use is 2300 mah. Check your USB power supply for excessive voltage output. It should be about 5vdc. It is very possible that you have a bad battery. That can cause overheating. The standard change time for rechargeable batteries is 14 hours. If you charge a 1300 mah battery for that time, you are overcharging it.
n1chu
Energizer Ultimate Lithium is a AA size battery that is acceptable to use in the handheld scanners that call for AA batteries. I’ve been using them when I attend airshows due to their extended life (not to mention reduced weight). Yes, a lithium ion battery has a higher voltage per cell so the energizer bunny must be doing something to throttle back the voltage... either it not a “true” Lithium ion or it’s got some sort of dropping resistor built in? Don’t k ow for sure. But the answer to that is just a google away.
tvengr
Well Known Member
You said you installed a new battery. The 436 uses 3 batteries. Are the other batteries rechargeable? If not, that could cause the overheating.
MisterLongwire
Ummm...last I heard is lion batts are higher voltage...someone please correct me if I am wrong but that is one of your first mistakes. Is it that difficult for you to buy regular mimh batteries that you have to resort to lion batts? That is a BIG NO-NO
MisterLongwire
Tvengr- this isn't directed to you. N1chu- bud you are gonna fry your radio. Just because it is same size don't mean its gonna work. Those batts are higher voltage than reg batts and higher than nimh,/nicad batts.
CT
"The nominal voltage of lithium-ion is 3.60V/cell. Some cell manufacturers mark their Li-ion as 3.70V/cell or higher. "
tvengr
Well Known Member
I was recently looking at the Energizer website. The Energizer lithium AA cells are 1.5v. Normal lithium batteries are 3.7v.
kb3isq
Shippensburg, PA
-The Energizer L91BP-8 Ultimate Lithium AA is listed as 1.5 VDC, this battery should be OK to use. Don't know if it is a true Lithium ion though.
dougjgray
Englewood CO
Have you tried a different ac adapter, maybe it is not working and the batteries are dead. Or have you tried recharging the batteries in a charger?
WeldGuy
Canal Winchester, Ohio
Try putting three alkaline batteries in it and DO NOT plug the wall adapter in it. That will tell you if you have a battery problem or a radio problem.
kevincl
yes i try normal no rechargeable batteries without plugging it in and the radio does not open,
I put my batteries in the external charger and it does the same
So the problem comes from the battery that it would not be strong enough to know it?
What kind of battery should I take?
