p-25
ScannerSK
Weld County, Colorado
First you will create a new "TGRP" if you did not already. Next, in the settings for that TGRP you will go to "TSYS" and select "NEW" and then press the "SEL" button on the scanner to enter the system settings. In the system settings is where you will select P25.
I hope this helps a little.
Shawn
