P or M1225 Programming
Johntorg
Beaufort, SC
I will be trying to program my P1225 radios. I have a RIB and will make the programming cable. I read the following on Bat labs:
Here's the pinout for the P1225 programming cable:
Looking at battery from rear contacts left to right
X1 X2 X3 X4
X2 Data Ground X3 Data Input
My question is: Do I install the battery and make contact through the charging contacts in the backof the battery, or do I leave the battery off and provide signal, ground and battery voltage through the radio contacts?,
BlueDevil
WA
Are you using a homemade programming cable or a programming cable you purchased?
You would most likely take the radio off of the P1225 and use the contacts on the radio.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Leave the battery off and provide power to the contacts on the back of the radio.
Johntorg
Beaufort, SC
Thank you both. I am using an Ebay RIB and a home made cable. I tried it through the battery and it worked fine. I had to hold both bare wires against the battery terminals, so I need to create a better long term cable setup Next step is some channel programming and converting to narrowband.
cmdrwill
So Cali
P1225 Programming Cable Pinout
The photo is similar to the one I made from a bad P1225 battery years ago. The red and black are 7.5 volts and gnd/- power. This one has the RIB built into the DB9 connector housing.
jeepsandradios
East of the Mississippi
I have the factory motorola programmer. It is just a charger base with another pin. I made a few of these when i worked at the shop. The board had runs to the back, but i just soldered wires to the battery tabs. Drop radio in charger base and program. SP50 did the same thing.
cmdrwill
So Cali
I have both the Motorola factory battery eliminator/programming cable and the Motorola 'drop-in charger' programming stand for both P1225 and SP50 radios. And being a service shop we build some very special cables and other test jigs here.
I personally prefer the battery eliminator programming cable.
