Hey guys, I had a couple of questions about my new Pro-668.
First off, I am scanning this system: Alabama First Responder Network Trunking System, Varies, Alabama - Scanner Frequencies - The Calhoun County part of it. I am also scanning the Talladega and Sylacauga sites.
I am using the antenna that came with the scanner but also have tried the RS Telescoping antenna: https://www.radioshack.com/products...d-telescoping-whip-antenna?variant=5717063301 They both seem about the same but should one be better?
The problem I am having is picking up some transmissions. Sometimes it will be clear, but others the connection keys up but then I don't hear some transmissions. Other times there is a beeping sound like a busy signal, and I thought it could be encryption but it's the same talk group I can hear dispatch and units on clearly at other times.
I checked and I only have the primary and alternate sites frequencies. So, a total of 8 for the entire system.
My site Data Decode Thresholds: Low: 15, High 95. ** Not sure if this should be changed?
On my Advanced settings, I just read where these should be changed, so if I need to change something here, please let me know.
Search AGC: Enabled
Global AGC Mode: Global
Global AGC: Disabled.
DSP Level Adapt: 52
ADC Gain: +2db
DAC gain: +2db
And on the top of my scanner the bar shows: Play, the T in a box blinking, and a G.
So basically is there anything obvious that I can change with my settings to get a clearer and consistent reception? Sometime's I can hear a certain police dept pretty well for like 30 minutes, but then if there is other traffic it kind of loses all of it and I get silence... So I'm thinking something may be going on there.
Thank you for your time.
Search AGC: Enabled
DSP Level Adapt: 52
ADC Gain: +2db
DAC gain: +2db
