devicelab
Whacker Extraordinaire
Question for the P25 experts:
Recently, I've been having regular conversations on a P25 repeater. I'm mobile using a Kenwood TK-5720 VHF (factory new and latest firmware) and the other party is using a Motorola XTL 2500 VHF (base station) that has been professionally tuned. I'm using a properly tuned Larsen VHF 5/8 whip. Base station also has external VHF antenna.
Part of the problem is topography of the area. The repeater is on top of a mountain and my mobile station (we think) is likely under its shadow -- that is to say, I'm very close (< 2 miles) and the other party is farther away -- probably ~20 miles.
About 75% of transmissions are solid and there's no issue. The problem is that on receive, I hear a quick audio blurp but then no decode. On the 5720 I can see strong RF on the RSSI meter -- so it's not a repeater signal issue.
As a random test, I used an XTS 2500 (900 meg) and tuned NMO antenna and we were seeing very good decodes. We did hit issues where the signal dropped out but that was likely due to obstructions, etc. The other party was using a XTL 2500 900 meg radio. Thus, we had to (2) IBME radios. The funny thing is that my receive decodes seemed better between the Motorola radios. The audio quality was not nearly as good -- the IMBE seemed to struggle a bit -- but the audio still came through and was able to decode. The 900 repeater is on the same mountain and I was mobile in the same area. So even though it wasn't perfect, the XTS/XTL combo seemed more reliable.
This brought up an obvious question: Are there any interop issues between IBME and AMBE+2 radios? Does the AMBE+2 vocoder require more P25 frames for decoding purposes? In other words, could the Kenwood be actually making it worse..? I do realize that the repeater plays a role here too but I don't many details there. I'm presuming it's a Motorola repeater but I'm not 100% certain.
Anyway, I'm just curious if AMBE+2 radios require 'more' in order to decode properly than IMBE radios. I'm thinking the BER threshold is higher on the AMBE+2 and that might be actually hurting the decode performance a bit.
A side note: we've noticed that on weekends, our QSOs seem noticeably better and more consistent. Could the weekday RF around the region be causing issues..? Is it possible for an area to become RF saturated?
