P25 phase 2 harris system
Fearthis50
Nj
Can anyone here tell me what is happening when a radio registers to system....I understand a little but was just wondering does harris system look for serials and not just correct sysid and nac and lic? I'm sorry if this not valid question I'm new to this and I know how all thos harris stuff is secret squirrel.
Fearthis50
Nj
no one cares to input what im getting at is my scanner picks up system but cant program a radio to act like scanner dont get it?
BruceMichaels
Not "Some People"
Flying Over You
The scanner does nothing more than decode the control channel and does what a radio does - track talk groups. A RADIO "affiliates" with the system meaning that there is a user ID that is authorized to receive specific talk groups. If the controller sees your ID and it is not on the list to be on the system, it is flagged and sent to the system administrator to see what is going on. Best case senario is your radio will be bricked. Worst case senario is your radio will be bricked.
That being said, there ARE ways to get around it. Using certain Harris software in your radio can allow the radio to be a scanner and not affiliate with the system.
Make sense?
Fearthis50
Nj
thanks bruce i get that....im just not familar with harris p25 phase ....except i know i have valid id and system info set to not login radio hears nothing....set the register it will not ......i know personality is right cause its cloned from working radio with exception of id i know the system does not have lla. so i just dont know why my radio wont open up....gotta be something else to make a harris radio hear the phase 2
overtheair
Durham,NC
Check with the dB to make sure everything is correct with the system in question. Other than that without seeing the code plug your radio could be severally out of alignment
Fearthis50
Nj
I need someone that knows harris phase 2 systems well to tell me it cant be done seems to me that if your radio isn't put into system and registers then audio wont unmute ....however a Motorola radio works just fine
KevinC
32D2T/957.282
I'm everywhere Focker!
Maybe your radio isn't P2 capable? Or you have some parameter set wrong in the programming?
I know those two responses really don't help, but without knowing the exact radio (and what options/FW/etc it has) and without having access to your radio programming file no one can really help you.
But receiving P2 is no different than receiving P1 (assuming the radio is capable).
rescue161
KE4FHH
Hubert, NC
I can try Monday when I go to work to see if I can receive audio on a RX only talkgroup. I'm a System Admin for a large Harris P25 Phase II system on the East Coast.
Are you listening to a multi-site system? Are you certain that other radios are affiliated to the tower that you are trying to listen through? If they are not affiliated to the same tower that you are monitoring, then you will not hear any traffic on your radio until it affiliates and creates the demand for that traffic on that tower.
Fearthis50
Nj
Yes multi site ...yes there are on the same tower....since your a admin I know my system doesnt have lla but what else is the system looking for to register besides nac sys Id and unit Id ....doesnt make sense to me. Example given if you had a radio go bad on your system ....and had a new one in box could you just dump the personality from bad radio into good one and presto would work fine without changing anything in system computer
rescue161
KE4FHH
Hubert, NC
We always remove the radio from the cryptonet and the UAS and then enter in the new radio from scratch. The serial number is tied to the radio ID in the system, but I'm not 100% sure if that plays a role in you not hearing traffic.
Fearthis50
Nj
Thank you that's the answer I was looking for .....then so yes on a harris radio on harris system the p25 phase audio will not unmute unless it registers with system and matches info....so really it's like lla but built into system....has to be the case ...motorola radios must be different cause it doesnt have to register to unmute weird stuff but must be the way it is
Fearthis50
Nj
If there is anyone else out there using harris radio non login register affiliate whatever you want to call it to listen to p2 system and it work please explain to me how if you know
overtheair
Durham,NC
Harris radios will unmute if they are programmed properly.
Fearthis50
Nj
Does anyone here know what settings in rpm need to be to program a p7300 for monitor only of p2 system ?
Forts
Mentor
Ontario, Canada
On all your talkgroups, uncheck Transmit. In your system setup set Auto Registration to Never. Obviously you'll also need a working copy of RPM and an appropriate programming cable.
Fearthis50
Nj
Forts ....all this has been done radio per FCC menu locked on site -89 db and talk group selected but no audio and doesnt even so lid or data of tx unit on talk group
Forts
Mentor
Ontario, Canada
1st guess..... the settings in your IDEN table are wrong.
2nd guess.... the system NAC setting is wrong
Fearthis50
Nj
Well heres what I did read personality from working radio...changing the setting to non register then programmed new radio . And that's where I'm at doesnt here nothing.....first Ijust simply cloned radio but apparently the system knows it's a cloned radio and will not register
Forts
Mentor
Ontario, Canada
Does the new radio have the P2 feature enabled?
Wait.... I see you already have another thread on this topic. No reason to be discussing it in this one.
