P25 programming
JackRoberts23
Recently, while trying to find different ways of programming P25, I found this
"Instead, I found a new monitoring technique that seems to work well without any risk of affiliation. Instead of programming a trunk system, I instead have inputted the listed system voice frequencies as RX only conventional channels. For each voice channel, I set the NAC to F7E to admit all traffic. Next, the conventional profile I set up is configured for Astro mode only, and I strapped the profile with a single Astro talk group, set at 65535 (unmute for all talkgroups). I then set all the voice channels, 8 or so, on a scan list. Essentially, I have each channel configured as a P25 conventional channel, and low and behold, it actually works pretty well. The trade-off is I dint necessarily hear everything I want to, or hear traffic I don't necessarily want to listen to, but its not too busy of a system, so it's been pretty good so far."
How was this person able to achieve this? Can anyone help me figure out what the OP did? The frequency I need is 501.050 as a control channel and 477.2125 is the talkgroup frequency.
Thanks,
Justin
KevinC
32D2T/957.282
I'm everywhere Focker!
He's able to achieve it by doing what he posted. And talkgroups don't have frequencies by the way.
JackRoberts23
How did he do it? When I try to do it I don’t know where to put the NAC he’s talking abt or the ASTRO talk group ID?
“And talk groups don’t have frequencies by the way.” Well if 501.050 is the control channel, what would that make the 477.2125?
GTR8000
NY/NJ Database Guy
BEE00
Your post makes absolutely no sense. 501.050 is a control channel for the UHF simulcast cell of the Nassau County P25 system, and 477.2125 is an analog frequency used by ARFF at the Long Island MacArthur airport.
Buy a scanner and stop screwing around with stuff you know nothing about.
JackRoberts23
477.2125 is a frequency I found for the 4/5 precinct for NCPD. Why don’t you try helping me learn, instead of telling me to buy a scanner and not get the opportunity to learn?
JackRoberts23
So please help me. Let’s ignore that frequency for now, and help me figure out how to program the 501.050 the same why the guy I quoted did
ElroyJetson
This isn't new. Listening to trunked P25 system channels in P25 conventional mode is a very old technique, people were doing it before trunked NAS had yet been publicized.
All you're doing is setting the radio up to scan the voice channels as if they were conventional channels in a conventional scan list, but configured as P25 conventional. It's kind of useless on a busy system, but if the system is not very active you'll be able to track conversations most of the time and it's quite satisfactory.
Just program up ALL system channels, both voice and control channels, and have nuisance delete assigned to a button. When the radio locks to the control channel, hit the nuisance delete button.
This is a motorola system right? Why would you want to program the control channel in this scan list? Just no...
JackRoberts23
I’m still learning how to program P25. If all you guys are gonna do is discourage me from learning then I will figure it out elsewhere. I can here because it is a reliable source but you don’t seem to be the nicest bunch.
If you want to help me learn please PM me
KevinC
32D2T/957.282
The text you quoted in your first post explained how that person did it. Another member told you how to do it. What exactly are you expecting?
JackRoberts23
I’m not sure how to program the ND. The person I quoted first seems to have more of an understanding of ASTRO 25 than me. I will work on what he said all night and see if it makes a difference.
He puts a strap, a talk group ID and idk how to do that stuff
KevinC
32D2T/957.282
Now you’re getting somewhere. Make an attempt on your own, you’ll feel proud of yourself when you figure it out.
And I have no idea what system you’re trying to listen to, but I suspect you’ll be disappointed with the results.
JackRoberts23
Ok. Please tell me if you think what I did is going to work.
1. Created a new conventional personality and made it Rx only and ASTRO only
2. Put the NAC to F7E like the guy I quoted
I can’t seem to figure out what he meant by strapping each channel with a talk group ID?
ElroyJetson
Not possible. Without being in trunked mode, you will not be able to selectively scan by talkgroups. NAC code is all you have.
