As they are on different systems it could be a weak signal problem, that the transit agency are received much worse with a too low signal level.
What does the display say about signal bars and the RSSI's dBm value while trying to receive the signal? You can push the button below the SYSTEM text in the display and within 3 sec begin to scroll thru the systems and you will have 3sec to check the signal strenght on that system until it continuos to scan.
This could be a case when you'll need to choose another mode for the filter setting. If the filter now are set to Normal then try the Invert setting, or the other way around.
/Ubbe
Hi there,
At the moment, Signal Bars are present full five bars and RSSI goes between -50/-60, Squelch is on 2 and the Filter is Wide Invert. But when a Talk Group pops up for not even a full second it seems then the word DATA and RSSI disappear. Also note, the readings only displayed this when I moved the radio from the position that I usually have it in when listening to the police. If I move the radio further back on my desk then signals and RSSI disappear only on the transit system.
Normal filter and Invert filter - signal bars and RSSI disappear in both positions on desk, and Squelch on 2.
I posted this thread because if I move squelch to 1 so all the P25s come in, then the Fire which is an Analog almost busted my ear drum haha.
I just tried it with Wide Normal, and instantly a full conversation picked up same signal bars and RSSI as Wide Invert but now its doing it again, the only thing different is now the word DATA disappears and signal bars and -60 flash or stays put as DATA disappears. When DATA, Signal Bars, and -50 all are present, I haven't received any traffic still says ID Searching. Squelch on 2 for all of this.
Side question, what should the Hold Time for each, I have two p25's, one analog, and one EDAC. Currently, I'm only on the transit system.
As I'm typing this, I have received the original conversation, the next two did not pick up the talk group flashed, and now I just received the fourth one. in this ten minute span. Back in the original position on my desk too.
