P25RX Firmware Updates / Testing
epersson
KB1SGU
Minor... but BTConfig locked up once, P25 was still sending audio, reloaded BTC and it was fine. also once the p25 would not be rediscovered after a config download. Kept trying and cycling through. Cycled P25 power and it came back up fine. Still two thumbs up.
  • Like
Reactions: btt
btt
Banned
Banned
Wa State
That sounds like bugs in the BTConfig software itself, not firmware. If you figure out a way to reproduce the issue, let me know and I will get it fixed. Btw, the issue that I mentioned previously regarding ESD causing BLKS/SEC to drop to zero turned out to be a one-shot-reset hw interrupt process that would get knocked out by an ESD event (Not the USB interface). That interrupt process recovers fine with the new firmware. I believe this version is the most rock-sold, best sounding yet.
epersson
KB1SGU
Just did it again. steps were. I plugged the P25 in but BTC not running, started it afterwards. Didn't ID it, unplugged P25, plugged it back in it synced. Not a big deal. Have a great weekend.
  • Like
Reactions: btt
btt
Banned
Banned
Wa State
Thank you sir! I will see if I can reproduce it. You have a great weekend too.
FP761
Thanks for reporting on the 'add_tdu_silence' option. I am going to make this option default off for the next release.
Hi Todd,
I just noticed that in _0709, the default is “ON”. I had not realized that when I tried _0709, since it was going to be “OFF” for future versions.
I am going to disable and listen for awhile.
  • Like
Reactions: btt
btt
Banned
Banned
Wa State
Hi Todd,
That option was changed to be default off, but the description was not. Thank you for pointing that out. I do think you should try turning the option on and see if that improves the issue you have been having with audio. This option was default "on" in previous versions.
btt
Banned
Banned
Wa State
Is there an option to have it roam but it only changes to another control channel if it looses signal from the current one?
There will be more options added soon, but for now the easiest way to accomplish this is to the set the value very high for the "switch control channel after" xx seconds of inactivity option. Set this to 300 seconds for example. If the signal goes from readable to "lost", it will only take 10 seconds before it starts looking for a new control channel. Once it starts searching, it will only stay on a dead (no signal / sync words) channel for milliseconds until it once again find a signal.
FP761
Hi Todd,
Attempted to load 3-17_1109 but am stuck. Unable to get the 25RX to run. Has the 4-Flashes on power up. I tried holding the TG button during powerup both the short duration and long duration. Was there an alternate method?
btt
Banned
Banned
Wa State
Hi Todd,
Sorry about that. The _1109 update had an issue where the BTConfig gets stuck in a loop due to a change in the configuration structure size / crc calc error. Try version 03-17_1649.
FP761
OK. I see that the DB Search did reset. I will enter my System CC now.
  • Like
Reactions: btt
rdlafore
Acworth GA
That caught me a couple of weeks ago. Some versions do that. When the update says "will reset configuration to default values". The primary freq gets reset to 859.xxxxxxx.
  • Like
Reactions: btt
