It's all working fine again Todd!!-edit: @kruser, Hopefully, the Signal Insights issue is fixed in version 06-03_0743
That is an old option that isn't needed anymore. I'll get that removed in the next release.I am running ver 0743, under the Advanced tab I have “P25 Mode: Re-init P25RX after 3 minutes of not receiving a P25 sync word” checked I was running in roaming mode, but it’s not holding for 3 minutes but rather about ten seconds. Perhaps I am just not seeing how this is supposed to work....🤔
The new version (0603-2157) is distorting for me on P2. The 0527-1909 was better and am reverting. No changes to BW or anything between versions, just audio dropouts on P2 on my local simulcast system.
Yeah I noticed that too, I am going back to 1909 - very solid for me.
I dunno what it is with CLMRN but if you look at the graph, when monitoring the 700mhz site, its like this constantly fluctuating wave... the 325p2 on that site (Troop H), just simply could not handle it - the constant up / down and would not really pick up much - even the SDS100 struggled. The P25rx can pic stuff up but even still calls get interrupted occasionally.. it seems to be a very troublesome location (Southington/Plainville line). FWIW the G4 would also have issues here and there.
When I am at home I monitor a different site, an 800mhz site, and on 1909 its super clear no issues. I have the filters at 12.4khz
Thank you!I've been evaluating 2021-06-03_2157 and everything works as it should across all OS platforms.
Audio on P1 and P2 talkgroups on the Illinois STARCOM21 system (850 Mhz system) sounds identical compared to another P25RX I have that is running version 2021-05-27_1909 with the same exact settings.
That's what I thought, it was a female dispatcher too for Litchfield Country Fire / EMS :-/ so that explains thatThe MAC_END_PTT is a signal sent by the P2 system that indicates that the call has ended for the TG indicated by the grpaddr (group address). The transmitting radio let up on the push-to-talk button. The listening radio (P25RX) then returns to the control channel. It appears to be working exactly as it should.
Maybe I didn't give it a good try, or I had mobiles with problems. I'm trying again and will eval for a few days.I've been evaluating 2021-06-03_2157 and everything works as it should across all OS platforms.
I tested on both. As I said above, I'll retry 2157 and let you know.I made version 05-27_1909 the new stable version based on your feedback. I can't test P2 here yet, so I'm not sure what the cause would be except possibly the new MCU drivers. Did either of you happen to test the versions between 05-27_1909 and 06-03_2157? I may have to give up on the new driver code for now.
