P5100?
wanabe
So I picked up a p5100 scan model with p25 trunking on the cheap. I can program 2 Edacs systems with Rpm10b07 and they work, but for some reason, if I add a p25 trunking system to it, it throws out “Hardware Err=0069 00 0D97BC” The p5100 has Pers ver 69.00, Flash Ver J2R18H09, Bld Date 02/23/12, Dsp ver F4R06M05, Sysgrp #128. And each time I program with RPM, a box comes up looking for fw upgrade location on my computer. I always press ok and the box goes away, but I’m thinking that is looking for a fw file. Kind of stumped right now. If any one has an idea on what I need to do, ( Mark C? )..lol! I’m all ears, Thanks, Bill
wanabe
Ok. After some suggestions ...apparently I need F8 or F9 dsp for the p25 trunking. So I have to find those and also info on how to do it. In RPM or Radio Maint? Little confused....and I was told my fw H09 will work with it. But do I have to reload the fw H09 before, after or not at all when I load dspF8 or F9?....maybe someone would be able to help this pea brain of mine! TIA
Forts
Mentor
Ontario, Canada
There are 2 components in play here... J2R18H09 is the radio code (firmware) whereas F4R06M05 is the DSP version. Your FW is current for that model radio however that DSP only supports unencrypted conventional digital. F6xxxx DSP is for encrypted conventional digital, F8 is for unencrypted P25 trunking and finally F9 supports encrypted P25 trunking. So, you will need F8 which I can hook you up with. Feel free to message me here or over at the other site (I replied there too).
Forts
Mentor
Ontario, Canada
Oh, and to answer your second question it's written to the radio using the Write Radio dialog in RPM. It'll query the radio when you do a write and a dialog will pop up giving you the option to select FW/DSP files.
ElroyJetson
A P5100 is a feature limited radio. There are some things that it won't do that a P7100 will do. It's been a while and I've forgotten the details but I seem to recall that it limits the number of channels and groups and systems it can support, plus I THINK that P25 trunking may also be off limits, but it has been a while and I'm not sure of that. These days, P7100s are dirt cheap so you should just get one and be done with it. Even P7300s, built on a much newer platform, are cheap enough and can be hand for under 200 bucks. But they do require upgrades to your RPM installation.
wanabe
Elroy, Thanks! I’m in Florida too...west coast....l’ve been following you for years..you are very knowledgeable! The P5100 has 128 group limit and the one I have has feature # 39. I just need J2R18H09 to load along side the F8 dsp I just received. Unless you know how to extract J2R18H09 from my P5100. Or, Elroy, can I use the “Load Compressed Code” option and load the F8 dsp by itself? When I use RPM and try and program the P5100 a box comes up and wants me to load both dsp and FW. It won’t let me just load the dsp. Im still trying to figure this out, Thanks
sbk1982
P5100 is a phase 1 capable P25 radio but it wont do any sort of P25 encryption.
ElroyJetson
To update your firmware, you need both the radio code and DSP code files. You can't get away with just one of them. And those files need to be compatible with each other AND the feature package in your radio or errors can and will occur.
Yeah, it's encryption that a 5100 isn't supposed to be capable of and there's a channel and group limit. If you found a way to remove feature 30 from the encryption string it'd be a 7100. Good luck with that!
wanabe
Thanks Elroy.....Can’t find the FW file...I’ve looked.....So I guess I’m sol until I find a FW file....or can I extract the one I have loaded in the P5100? I don’t know how.
Forts
Mentor
Ontario, Canada
I have the FW too... I can send it to you later today (Sunday) if you are still in need.
wanabe
Yes Please Forts!! Thank you so much! I’ll send a pm.
wanabe
Got P25 working! Thank you for your help, especially Forts!!
