PA0RDT Mini Whip ? Users ?
dlwtrunked
Would it be a bad idea to use a splitter and have this antenna along with my discone? Don't want to run a second coax. Looking at mounting it about a foot underneath my discone when I am home.
In theory that is not a good location. I should be as far away as you can and higher than nearby such objects.
bearcatrp
Land of 10,000 taxes
No transmitting. Just receiving. How about using a splitter but mount the antenna on its own pole away from the discone?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you want to use a splitter you will need a way to combine the 2 feeds from the antennas into 1, then feed that into a splitter. Extra runs of coax would be needed.
Bite the bullet and feed the mini whip separately. Much simpler
Mike
bearcatrp
Still want to try a splitter. Just need to find a good one. Can put the splitter close to the house where my connection is at. Have about 40 feet from there to my discone. Will only be a temporary setup as I want to take this antenna with on my camping trips. If it does work out well, will order a second one for a more permanent setup. Maybe then I will run another line of coax.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I think you might be putting the cart before the horse here.
You will need a way to combine the 2 sources on one cable first. THEN you can consider a splitter. Extra cables, extra waterproofing, etc.
Get the picture?
bearcatrp
Get the picture?
Will have to run its own coax. There is a power feed unit that goes between the radio and antenna.
bearcatrp
There is a power feed unit (grey box) that needs plugged in on the side. Has to be 12v 100 mA. I need something portable for my camping trips. My 1st time dealing with something like this. My google fu comes up with small batteries For like an ups for computers. Suggestions? Also, for when winter hits and not camping, would my Astron power supply work or is that to much power. Appreciate and help on this. I did email the manufacturer for there suggestions.
bearcatrp
Just ordered the power supply that was recommended by the manufacturer. Will be a little bit before I can test it out. Its a wall wart. Will use an extension cord to power it when out camping.
bearcatrp
Emailed the manufacturer about grounding. Said not needed unless a noisy environment. Being out in the country, don’t think I’ll need it. Out camping now. Once these storms get out of here, plan to set it up to test it out. Will be a few days. Nasty weather up here.
bearcatrp
Just came in from outside my camper testing this antenna out. Only 20 minutes due to mosquitos eating me alive. Brought my tripod and pvc mast. Got it about 10 feet in the air. Am 2 hours north from home by the lake. Wow, this antenna really brought in the signals. Was listening on 15.770. Orietal, sounded like japanese. 5 through 7 MHz had allot of signals I could sit on and listen as they faded in and out. When I get home to set this up, and compare it to my wire, then I’ll know for sure how well it performs. If this does as good at home as up here, will order a second one so I can leave the one at home up permanently. Will come back with a comparison soon.
dlwtrunked
A lot of people who have never tested one of these criticize them. I first used a similar one around 1987 or so. Those who have used one like this place properly away from noise know their true value.
bearcatrp
Am hoping it works at home as good as it did last night. Have to figure out the best way to mount it on the pole. It’s so small. Just used a Velcro strap last night to attach it to the pole.
bearcatrp
Got it temporarily set up about 10 feet in the air. Been using it for an hour. Looking for weak signals to see how well it does. So far, it’s clearing up voice that I can understand whereas with the wire, can barely make out the voice. It’s reducing the noise floor so I can understand the conversation. Db is a little better too. Will be comparing this to the wire for a week or so before I decide for sure it will replace my wire. But so far, am liking it. Want to try some daytime scanning too to see how it does.
bearcatrp
So far this antenna is doing good. Am able to pull out signals the wire couldn’t. Only draw back with this antenna is it needs power. You lose power and you’re done. Am considering keeping my wire up for backup. Will be keeping this one for home use. Debating on ordering another for my camping trips. Do have other antennas I could use but don’t think they will be as good as this one. Folks stuck with an indoor antenna may want to consider this antenna. Small foot print. Just don’t attach it to a metal pole.
