Pax River Trunking Sys.
anomovfa
According to the Data Base, Pax Riv. operates a Motorola Type II system. I have a Radio Shack Pro 95, programmed for the Frequencies, Offset, Base, and Spacing per the RR Data Base.but cannot hear a thing, even with the radio in Open mode. I am about 3 miles line of sight from the base which seems within reasonable range. Any suggestions on what I'm not doing correctly to receive this system would be appreciated.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
We had a thread on this recently, but I can't put my finger on it. I believe the poster discovered most of the ops have gone to the 380 mhz fed/mil trunk, which cannot be received on the 95. Evidently no one put a ticket through to remove the old 400 mhz system from the database, and no one has taken the old system out of the wiki either <sigh>
You'll need a digital trunker...
best regards..Mike
groftcc
Most if not all operations have moved to the new system.
Craig
anomovfa
Thanks for all the replies. Looks like a digital radio is in my future - sometime!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
And someone should put a ticket out to the DBAs to drop that old 400 mhz listing...best regards...Mike
[edit] Which I have now done - as well as dropped the trunk system refs from the wiki listing...
