PC not seeing USB connection to APX radio
ccsd157
Camden NC
So, new issue has cropped up. The radio, cable, and computer have all been used together many times, but for some reason, the PC will not see the connection anymore. Watching the device manager when I turn on the radio and nothing happens, I have tried different USB ports, I have installed tuner and the APX USB driver package...still nothing.
Anyone had this issue before?
dgruver911
Newton, KS
What version of CPS are you using? You may want to make sure you're using the latest. I can't recall exactly when, but seems like early last year there was a thread on this where a Windows 10 update killed the standard Motorola USB driver. The initial fix was to use the driver that came with with the tuner software, but they fixed it with an update in the CPS.
edit: Found the thread it was back in September. Version 21.40 is where they fixed the issue.
ccsd157
Camden NC
Thanks. Turns out i was a version behind. I uninstalled everything and installed the new ver and all is well now. Thanks
