APX CPS not finding radio
michaelpauline
had to make a few changed to a codeplug and now im ready to flash the radio. CPS (R35) isn't able to find the usb connection when i go into devices in under USB Serial and not a network adapter what am i doing wrong here I've updated the codeplug before and it was working. I saw this on the readme file, so whats the fix
"Radio device may not enumerate properly when connected to PC"
MTS2000des
5B2_BEE00 Czar
Two things: CPS R35 has all drivers necessary. If you're able to connect to the radio, you should see (and hear) WDM make a "connect" sound. See in the device manager if an APX radio shows up. You might also try disabling any firewall or other software that may be blocking the connection to the radio. Worst comes to worst, sometimes uninstalling and re-installing APX CPS will fix the problem.
