DSDPlus Per-Call Recording
CanesFan95
Was Homeboys-Scanna
Banned
FL
Is there a way to make DSD+ save an .mp3 file of each individual voice call as a separate .mp3 file? Right now, it combines everything into one .mp3 from all the different TGs. My VC-Record folder is empty. I'd like to make it save the TGID and date/time in each filename, if possible. This will help to identify unknown TGs by letting it run all day and then just playing everything back later and listen to save time.
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
I'd need to see a screenshot of your Control menu to see what monitor mode you're running but if you're running "Passive Digital Monitor" then the separated MP3 files would be saved in the DSDPlus\Record\[date] folders
DaveNF2G
Latham, NY
I have No Per Call Recording checked and DSD+ is appending audio to a .wav file on every transmission. It didn't do that before. How do I turn THAT off?
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Output menu. Or, if you are piping the audio to a wav file via a batch file (which was a popular configuration shown way back when).
CanesFan95
Was Homeboys-Scanna
Banned
FL
I think I figured it out. The setting has to be turned on in the VC Event Log and not the CC one for a 2-dongle setup.
Yeah, it's in the screenshot above. Make sure it's on "No Per-Call Recording" for both the VC and CC Event Logs.
DaveNF2G
Latham, NY
This is happening in single receiver passive monitor mode on a P25 conventional channel.
