Phase II PPS
GTO_04
Noblesville, IN
Can profiles created in an earlier PPS be imported into the new Phase II PPS_V00-03-11_Beta09 or will I have to start from scratch?
GTO_04
Thunderknight
Bletchley Park
If you have the older PPS and profiles on the computer, when you install the new version of PPS, it will ask if you want import the files it has found. Each new version of PPS has done that.
I have not tried an actual file import at a later time (post install).
GTO_04
Noblesville, IN
Thank you! I will give that a try then.
GTO_04
