There's a whole lot more to consider besides sensitivity in choosing an hf receiver. The fact is, if you can hear atmospheric noise and static, it's as sensitive as it needs to be. Adding gain is not going to bring that signal in stronger than the noise that's riding with it. If you're going after ssb, or digital modes, frequency stability becomes a factor. You don't want to have to keep retuning because the receiver drifts. The term is a bit passé now, but what about bandspread... how fast is the tuning rate. 1 KHz steps are too much for anything but sw broadcast. Does the receiver you want to use do 100 Hz steps? How about 10 Hz steps?
How's the selectivity? Does it have switchable filters? Does it at least have filters that match the modes it's capable of? A receiver with a BFO capable of receiving SSB is going to be a poor performer if all it has is a 5 KHz IF filter for AM. Do you even know what the IF filter bandwidths are in your receiver of choice? If not, maybe it's because the manufacturer didn't tell you because they don't want you to know.
What about dynamic range? There are 50 watt ute stations right next to 100kw broadcasters. What are the chances a low cost receiver will be able to separate them? Will it put up with a nearby AM broadcast station or will it roll over?
Pay attention to sensitivity at the higher frequency ranges, at the low end, you can almost ignore it. Again, if you can hear static and noise, it's as sensitive as it needs to be. All those other factors (and more) are actually more important than 'sensitivity'.
