PL-259 Socket Too Darn Tight
TomLine
Hamilton, Ohio
Is there a method to de-burr a PL-259 socket? I have a A/B splitter with one port super-duper tight. (The splitter is sealed up good, but I may investigate being able to replace the socket.
AK9R
Staff member
Super Moderator
Central Indiana
Are you sure it's a UHF connector (PL-259, SO-239) and not an N connector? The pin on a UHF male plug will appear to be very tight in a female N connector.
kj4jaq
Gulf of Mexico Galavanter
female N connector wont accept pl259 center pin unless forced and most likely broken. considerable size difference of center pins
chief21
Western NC (Summer); Tampa Bay FL (Winter)
This, in fact, can be a common problem in agencies where both types of connectors are used. The male UHF will start on a female N and, since the threads are similar, the UHF can be easily tightened down on the N. This totally destroys the N female, of course, resulting in an expensive fix.
TomLine
Hamilton, Ohio
It's one of these. Connector on left is bugger tight. Connector on right is okay. Swapped cables, ends, all that stuff.
900mhz
If you have a tap and die set...if I recall, a PL 259 is a 5/8 X 24 threads per inch. So, an appropriate die threaded on the port with issues may solve your issue.
dlwtrunked
Would dialectic grease insulate the surfaces from one another? Is there a conductive "electric" grease?
Yes, their is a conductive grease. It has metal particles in the grease and you screw in until those contact both surfaces with the grease holding them providing a seal. Such grease should match the metal in the particles with those of the surfaces inforder not to cause problems. Google "conductive grease".
AK9R
Staff member
Super Moderator
Central Indiana
TomLine
Hamilton, Ohio
Used a 5/32" drill (I think) bit to get it roughed-out. Then ran it backwards to smooth it. Then ran it upside down in the chuck to polish it.
Looks like the inner sleve was jammed in, and the flares squeezed it shut.
Feels smooth, a bit rough, but tested out okay so it works.
iMONITOR
Silent Key
S.E. Michigan
A lot of cheap connectors from CHINA have cast molded treads in crappy metal, not machined. Try a tiny bit of lubricant on the threads. Sometimes a PL259 plug will have excess solder on the outside of the center pin causing it to fit tighter than it should.
Example:
MTScannerNut
NW Montana
I use NO OX ID on my connectors: NO-OX-ID Electrical Contact Grease- Conductive Lubricant | Sanchem, Inc.
Been used in the telecommunications and broadcast industries for decades. I only use a very small amount and it not only protects against corrosion, but it does make the center pin insert easier. But as iMonitor stated, if it's a crap China connector or too much solder, grease won't make much difference.
