Playback echo on feed
Ret_Batt_Chief
Windsor,ca
I am recently getting an "echo" on my feed. Plays radio traffic and translation working, but each transmission repeats itself at very low volume.
Feed # 40337. "Sonoma County Fire-EMS and Sheriff Dispatch"
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
Volume maxed out on player and maxed out on computer and can barely hear your feed. So low barely hearing an echo..
Scanner or sdr setup, if scanner which one?
What streaming software are you using? Audio input needs to be increased.
Ret_Batt_Chief
Windsor,ca
BCT15X using Proscan. I'll try increasing audio input, but I'm afraid that will also increase echo
Enforcer52
Lake Livingston, TX
Are you using a mono or stereo cable to import audio to the computer. And are you plugged into front or back output jack. If stereo cable on back output, probably your problem, on back jack need a mono cable. If plugged in front jack, try the back jack, but if using stereo cable may still have the problem.
Ret_Batt_Chief
Windsor,ca
Switched audio output cable to external speaker output from recorder output. Maybe that helps
Ret_Batt_Chief
Windsor,ca
Stereo cable on back jack. I'll try mono next, but seems to be working much better. I wanted to use the recorder jack so could still listen to scanner. But, I do have several other scanners for monitoring, so not a huge deal
