A few questions:
- how far are you (if you happen to know) from where the actual NOAA broadcast is coming from? In my experience they're usually from an airport or close to one since those tend to operate 24/7 (at least the big busy ones are)
- what brand/model of handheld scanner are you using where you state you get a "full scale" signal on that frequency?
As for tips:
- turn off the Automatic gain, set it for something around 29.7 dB to 36.4 dB or somewhere in there, maxing it out or using the Auto setting is impractical for FM signals since it tends to cause RTL sticks to start having image/ghosting/intermod issues which is just bad all the way around.
- you appear to have two actual VFOs created (A and B) but on the display on the right side you've got all 6 potential ones (from VFOA through VFOF) showing up there in the same area so, my advice - because SDR-Radio aka SDR-Console can be a daunting app with a lot of complexity, get rid of anything you're not actively using at a given time; in other words, hide those additional VFOs if you're not actively using them and even get rid of the VFO-B as well unless you have actual need of it and actively use it
- I'm guessing you've adjusted the ppm as required even in spite of it being a TCXO version of the RTL sticks, it doesn't hurt to verify it against a known frequency like that one at 162.550 which is the same frequency we have here in Las Vegas, I can also receive NOAA at 162.400 but the signal is much weaker (but still readable at 36.4 dB gain) as noted in the screenshot
- I'm not sure why your spectrum(s) appear to be almost maxed out but that's not good IMO, it might be more helpful to adjust them so your noise floor appears at the bottom of the spectrum as required but that's a more personal setting so choose whatever works best for you
I'm getting a signal level that tends to show about -73 to -75 dBm on the SDR-Radio signal meter and it's damned "LOUD" - I have the volume on the app set to 5 because it's just booming but if you look at the actual spectrum. SDR-Radio does things a bit differently than other SDR apps I've used, so I can't say exactly what the levels are as if I tune the same thing in SDR# (using all the same hardware and the same 36.4 dB gain) it shows a peak of -15 dB and the signal is just as clear and booming in terms of audio quality.
Noise floor on these RTL sticks is typically -60 dB (I have the original R820T style, not the newer R820T2 which I believe has a slightly lower SNR around what, -65 to -70 dB from what I've read) so that's what I use as the basis meaning I adjust the spectrum so it gets that noise floor just above the bottom. This ensures that what I'm seeing is primarily signal and not a waterfall full of nothing but noise - I only care about the signals, not the noise.
Unless you're LOS with a tower broadcasting the actual NOAA signal or in a very close proximity you're going to get a signal but it might not necessary come in anything like a local broadcast will that is coming from a tower or antenna installation that's much closer.
Also realize that these are "cheap USB TV tuners" that luckily were discovered to work - not as well as a dedicated device like a scanner or communications receiver - as radio receivers. They won't match what a dedicated device can do but they will perform acceptably for most any general purpose. It looks like you're getting a signal so that's a good thing but of course these types of devices are not nearly as sensitive as a dedicated device can be.
And another thing: those antennas they include are still "bottom of the barrel" in terms of production quality, especially the cabling: it's cheap as hell and that's part of why the cost(s) for these devices are so low. You proved that to some degree already by attaching what is probably a better antenna, and the antennas that came with the RTL sticks you got don't have a decent ground working with them either.
They work, they just don't work great, but acceptably in most situations.
Here's what mine looks like presently:
And with SDR#:
I'm using an R820T stick fed into an MCX to BNC 6" pigtail which is currently fed into a "bazooka" dipole I made earlier this morning just as an experiment - it's basically 23.25" of a piece of coax (I don't even know what type it, to be honest, it was provided by Cox Cable years ago and I happened to have some excess piece of it) with the center conductor exposed and the braid rolled back over the sheath then stuffed into a piece of PVC hanging from a curtain rack in my apartment.
The antenna works better than I expected, actually, but it's "cut" for 127 MHz to help improve my civ air band monitoring just as an experiment, as noted.
Anyway, it looks like your setup is working, it just isn't going to perform nearly as well as the scanner will in most situations. Get some better cabling for the antenna and things will probably improve, and obviously try different antennas as well. I recently re-assembled the OCFD I made about a year ago and for whatever reason
now it works as I suspected it should have worked the first time but didn't. That's my general purpose antenna nowadays and it's basically standing right next to the bazooka one I made this morning.
Ain't perfect but they work...
