prcguy
I was trying to clean out the garage for the last few days and thought I would stack some random equipment in a portable rack to save some space. That as usual turned into seeing if the equipment works, which it usually doesn't then trying to fix it before stacking it away. I found an old commercial repeater I built and leased out a good 35yrs ago and when I plugged it in a few days ago it blew a couple of Tantalum caps. I replaced those and it came back to life but on some old 460MHz business freqs I'm no longer licensed for. I found a friend who still had a prom programmer program for the RF modules in the repeater on floppy which he transferred and sent to me and I programmed and aligned the little 2-10w repeater on GMRS. The stupid thing actually works better than most meeting 12dB SINAD at -122dBm or .178uV and has a very clean transmitter.
The repeater had a controller already wired to it and then I uncovered a Henry 200w amp that only needs 2.5w drive which I got it at the Dayton Hamvention for $100 and it was factory tuned in the 462MHz range. Then I uncovered a nice Motorola 526 duplexer I got at Dayton for $150 missing a cable and mounting brackets, so I hand made a new cable and brackets and tuned it for GMRS.
The portable rack came from Dayton also and was used to haul some junk home in the back of a friends pickup all the way from Dayton to So Cal. I didn't have a power supply that was adequate for the 200w amp so I bought a new 15V 66A job for $130 and turned it down to 14V, the most expensive piece in the rack With everything tuned up its doing 150w out of the duplexer with no measurable desense, not bad. Now what to do with it? GMRS rules only allow 50w and the Henry amp is designed to run nearly full power so its not gonna turn down to 50w. There are no tuning adjustments on this amp so retuning for the amateur band would be very time consuming unsoldering parts and moving them around. And we are only allowed 50w for 70cm repeaters in this area due to some military conflict.
So here sits this nice working repeater cobbled together from mostly scrap parts and I can't really use it. The layout is clean and uncluttered using a number of RF cables laying around that were a perfect fit. Not including the 10w repeater I built 35yrs ago from parts the total cost of this 200w repeater system is about $383. At least it was a nice exercise in frugality and it gets the parts off the garage floor and stacked nicely.
