Possible PPS bugs
belvdr
I guess what I’m getting at is I can’t take the profile on the pager and work on it with the older PPS since it was programmed by 4.xx I can rewrite a profile on 3.xx and then program the pager
More so it sounds like the 4.xx PPS needs some work
Correct you cannot import a v4 profile export or read a device programmed with v4 using v3.
You can use v3 to create a new codeplug and overwrite the v4-programmed device.
Or the FW since 1.35 was never officially released as a stable FW, it came out as a beta, it is now being released (without release notes). Have you tried to do a factory reset and then using V3 PPS?
mkinkade
Central Ohio
The out of range problem definitely seems to be related to PPS 4 latest release 36. I have pagers on 1.33 firmware programmed with PPS 4 that experience the issue. Same units previously programmed with 3-16-29E never had the issue.
ElevatorsAndRadios
yarewesog
SoCal
I have developed a workaround for this: turn full spectrum scan on, program the appropriate parameters as they pertain to your system, and the radio will go back in range instead of remaining OOR. Verified working with my G2 and G5. Long story short: Full spectrum scan MUST be turned on if you want your pager to go back in range if you are using PPS 4.0 or above. You're welcome.
mkinkade
Central Ohio
If it actually has to scan for it, it's extremely slow in my experience. But, I'll try it. Thanks.
ElevatorsAndRadios
yarewesog
SoCal
I said it's a workaround, not a fix, so it's obviously not ideal. The burden of responsibility is on Unication, not us users, to fix the bug. They should also improve those internal antennas while they are at it so systems on the secondary band are not constantly going OOR in the first place.
Firebuff66
CT
I'm using 4.0-36 software with 3 g5s on 1.35 with no issues.
I get them out of range and then they come right back.
I tried on the 4 different sites I can get from my house and all worked fine
mdsxfire
EDBM
Uxbridge, north of the river Thames
Sounds like a temp fix if u have no other choice, but unication needs to address this since none of our pagers ever went out of range like this before, and the ones that I have reprogrammed in the last few days with the 3.xx PPS are back to not having any issues. I’ll just stay with 1.33 programmed on 3.xx for now
mdsxfire
EDBM
Agreed the secondary band antennas are horrible I get it’s a secondary band but both are more than likely being used give us something a little better. Our second band is VHF which we had to use while county was working on our 7/800 tones and it was borderline useless
rr60
Good Intel. I have been slowly using PPS 4.0.36 to build a new code plug. I wrote one and all has been well, while stationary.
I was mobile with it a couple days ago and it was downright buggy. Many out of range
notifications. Some momentary, some longer. Interesting development.
Running 1.32 FW
ErikSwan
Boise, Idaho
Related thread:
I can't reproduce this issue on my VHF G5N with firmware 2.01. Note that the new G5N with 2.01 firmware can only be programmed with PPS v4; PPS v3 is not supported. I suspect this is isolated to the older revision G5 models.
