Power 12VDC cable dead short
mont1157
Since I cant seem to find a service manual on the BK M150 mobile, thought I would ask what the part number would be on the flat style protection diodes mounted near the 12 vdc cable. They are both cracked and burnt so they are the obvious culprits for the short.
Also, if there is a manual that can be found, that would be great. Not seeking software.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Before you go too far I'd try to figure out what caused the short originally.
mont1157
Already know, high voltage spike caused by jump starting heavy equipment truck to heavy equipment truck without removing the power fuse.
prcguy
The protection diodes usually blow due to reversing the +/- leads. Most protection diodes are simply a high current diode cross the DC entry point to protect from reversed power and in rare cases there is a Zener diode that will conduct if the DC voltage exceeds 15-16V. Without a Zener you can apply 100VDC to the radio and it will blow up but not harm the reverse protection diodes. So spikes from jump starting are usually never caught by any diode and it’s more likely someone connected the jumper battery backwards which can blow the reverse protection diode(s).
