Power Adapter Problems with PRO-96
mojicaman
I am trying to use both my car adapter and home power adater that I bought from RS and they both do not work on my 96. I have reset and initialized the scanner but the power sources still dont work.
Hopefully someone can give me a heads up on what more I can do.
Thanks!!
abqscan
DataBase Administrator
Moderator
AOA
Also how do you have the polarity set on the Adaptaplug???
mojicaman
I am using a 9V 300m-A Power Adapter and the C tip Adaptaplug both purchased from Radio Shack.
mojicaman
Erik - I see what you mean about the polarity. I turned it around to have the positive mark on the same side as the tip mark. The scanner turns on but does not indicate that there is a power supply plugged in. Maybe that how it works.
abqscan
Moderator
AOA
There is not an indicator on the 96 to say its getting juice. If it works without batteries, you fixed it :).
