Cruiseomatic
My 12VDC 60amp PSU gives of tons of RFI. Mostly between 25-30mHz. I've tried Ferrite cores on both 12VDC hot and neg, 120VAC hot, neutral and ground. Case grounding has no difference. It is coming off the supply wires that carry 12VDC. Sometimes its there, Others its not. I've thought about either an isolation transformer or a ground loop isolator. I think those are the same though. Only kick is, I pull about 50-55 amps from this unit and not sure how well a isolator would like that.
Here's how it happens:
PSU off, hot connected no RFI. On, RFI occasionally if not constant. Remove hot, RFI gone.
What else can I do?
Thanks.
What else can I do?
Thanks.
