BCD536HP: Power - to be used in Europe
Hoggorm
Kristiansand, Norway
Hi,
I'm considering the BCD536HP and was wondering what power it, and the power supply included, accepts?
In Norway we use 220VAC.
Will I need a plug adapter only or do I need a converter from 110 to 220V?
Will it be sufficient to replace the included power supply?
Thank you
DaveIN
Founders Curmudgen
West Michigan
Hello Hoggorm,
The included adapter is rated for both 110-240 ~ VAC, 50/60 cycle power. The radio input is 13.8 VDC, 400mA.
So the included adapter should work if you have a socket adapter for the mains socket. If not, then be sure to look for an adapter for 13.8 VDC output and at least ~750mA (more than 400mA) with a center positive (+) connector.
