Preowned Scanner, Old Settings
kentraco
Deltona
I just took delivery of a PSR 600 that's programmed with frequencies in another part of the country.
Is there a function that will clear the unwanted frequencies from the unit globally, or is one-by-one deletion the only means of doing so? So far, I haven't found anything in the manual that answers my question. I did empty the V-Scanner folders.
tvengr
Well Known Member
Baltimore County, MD
Turn the scanner off. Turn the scanner on. At the welcome screen, press and release 0 and then press and release 1. That will clear the working memory and reset all of the global settings to factory defaults. In your manual, look for Power-On Configuration Key Sequences. That is what it is under in my Pro-197 scanner manual which is essentially identical to your PSR600.
kentraco
Deltona
Thanks for your help. I'll do that tomorrow. I had considered the "nuclear option" of initializing the scanner, but the statement "V-Scanner memory is not affected when the scanner is initialized" in the manual led me to believe erroneously that programmed frequencies would remain as they were.
hiegtx
Dallas, TX
If you are going to use software to program your new-to-you scanner, loading your own programming file will wipe out any of the out of state information.
tvengr
Well Known Member
It looks like Volusia Co is going to a new P25 phase 2 system which the PSR600 will not be able to receive. The present fire and sheriff dispatch talkgroups are operating in phase 1 mode. Some phase 2 systems continue to operate in phase 1 mode.. A number only have fire in phase 1. You will be out of luck with anything in TDMA (phase 2) mode.
kentraco
Deltona
Thanks for that info. I'll enjoy it while I can and keep in mind that I'll need to upgrade.
tvengr
Well Known Member
Volusia Co will probably take a while to migrate from the present EDACS system. How did you make out erasing the memory? Do you have any programming software?
kentraco
Deltona
The memory's cleared. My used scanner didn't come with a programming cable, so I've ordered one. I'll get it Friday. And yes...I do have the software.
kentraco
Deltona
That's a new one for me. I have never heard of that one before. I use Butel ARC500.
tvengr
Well Known Member
The Volusia Co system is an EDACS standard system, also known as EDACS wide. The frequencies have to be entered in order of the LCN (logical channel number). I have never programmed a multi-site EDACS system. Since the frequencies have to match the LCN, I would think that you would have to set up 3 separate systems, each with the same set of scan lists assigned to a different system. If anyone else out there has more experience with this, feel free to chime in.
tvengr
Well Known Member
I think my last statement may be a little confusing. I should have said a duplicate set of scan lists assigned to each system.
krokus
Southeastern Michigan
For clarity, a phase 2 system with a phase 1 radio affiliated to it, will use phase 1 on the talkgroup that radio has selected. (I do not know if the system administrator can control this, to exclude phase 1 radios, or if it is inherent in the protocol.)
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Scan Control isn't new - quite the opposite. It's still around but don't expect any software fixes, as there hasn't been any in many years now. It pretty much ceased being supported shortly after the original PSR500/600 scanners came out. I don't believe the RR import or EZ Grab functions will work anymore as the database has changed a lot since this software came out.
The standards for these scanners are ARC500, PSREdit500 and Win500. Unfortunately Don Starr (author of Win500) hasn't been heard from in a long time and may be gone. You can find links here;
Mike
kentraco
Deltona
That may have some bearing upon a vexing problem I've encountered. Their web site shows a very simple cut-and-paste procedure for entering trunking data from radioreference.com into the ScanControl software. The interface for my PSR-600 doesn't look like the ones on the scanners used in their video demonstrations, and I haven't found any "edit" function on it that responds to the "paste" command.
It's such a simple problem that I would have been embarrassed to post it here, but ScanControl support has no solution. They tried to attribute it to the browser I'm using (Vivaldi), but I fail to see how the inability to "paste" into their program could be browser-related.
If this can't be resolved, I'll simply switch to other programming software. ScanControl is relatively inexpensive, so it would be no great loss..
kentraco
Deltona
Standard Windows shortcuts: Ctrl c - Copy........Ctrl x - Cut........Ctrl v - Paste........Ctrl z - Undo.
Nope. That doesn't work.
I just downloaded the demo of Butel ARC500 and had no problem cutting and pasting the data.
