Is there any reason why using DND Priority Scan Mode would cause Priority ID Scan to not work?
Here is the scenario: Priority Scan Mode is on with a 2 second interval. I was holding on a non-priority talkgroup in a P25 800 system that was inactive (no transmissions). A Priority talkgroup in the system became active, but the scanner did not go to the active priority talkgroup. (I had another radio going so I knew which talkgroups were and were not active.) However a priority conventional frequency became active and the scanner jumped to it just fine.
The only thing I can think of is that the DND Priority Scan Mode is "superseding" the Priority ID Scan function. Perhaps jumping off the trunked system every 2 seconds to check the conventional frequency isn't giving the scanner enough time to check the control channel for priority talkgroups.
