NewSDScanner
So my Pro-106 arrived today and I busted it out and MANUALLY PROGRAMMED (No software, don't have a cable yet but I wanted to try it out manually first):
1. I created a new Talk System and called it San Diego RCS. I set it as MOTOROLA 800/900.
2. I programmed the 1 CONTROL CHANNEL and 3 other ALTERNATE CONTROL CHANNELs into the talk system.
3. I added Carlsbad dispatch 1, 2, and Vista Dispatch talk groups by adding in their decimal code one by one. I also labeled each of these with an alpha tag so I could distinguish between the 2. I put both Carlsbad channels in list #1 and the Vista channel in list #2.
4. I set each of these to display a different color LED light.
5. I put the radio in SCAN mode and enabled both lists.
Now, what happens is I get the talkgroups displayed and the different LEDs turn on so I know that the radio is receiving the data but I get NO AUDIO no matter what level the volume is at. The only way I get audio is if I turn the squelch all the way down and then all I hear is noise. The little signal bars are all the way up and there is indeed a "T" (as well as a "G") icon displayed. I've also turned the global attenuator on and off with no luck. In addition, I've ensured that there is NO priority channel selected. Lastly, I've also double-checked my frequencies and they are fine.
So in summary... The radio appears to receive just fine because I can receive other traffic if I just turn it to search mode and I can also see the talkground names and LEDs when it's receiving. The reception is listed as 98%, the speaker works fine because I can hear other traffic... I don't know what this could be. Can someone please help? Thank you!
