Pro-106 Not Stoppin on Trunked Systems
zehndercraigm
I am having an issue with my Pro-106 while scanning. As it scans, I can tell that it's picking up a trunked group, because the "T" pops up and a strong signal is shown, but it does not actually stop the scan and play audio. If I go into manual mode, and listen to the individual trunked group, it works perfectly. For reference, here is the system I am listening to: Alcoa Trunking System, Cleveland, Ohio - Scanner Frequencies
The only frequency there is ever any traffic on is LCN 01: 462.03750
I imported the database using the scanner software that came with my unit and it has worked perfectly with every analog system I have programmed into it. As you can guess, I work at Alcoa and like to listen to the plant radio traffic, but I also like listening to the local repeaters as well.
I'll attach screen captures of the tables as they are entered, as well.
If anyone can help, I'd really appreciate it. Otherwise, I either am listening to the repeaters, or just the plant radio traffic.
Sportster77
Lake Co. Ohio
I have the following freqs in my PSR800 for Alcoa in conventional mode. but like you said almost all the traffic is on 462.0375.
1A = 461.4625
1B= 466.4625
2A= 461.5625
2B= 465.5625
3A= 461.6375
3B= 466.6375
4A= 462.0375
4B= 467.0375
5A= 463.7875
5B= 468.7875
6A= 464.8375
6B= 469.8375
If you see the guys from IWI inspecting or fixing the cranes in your dept. , look for the old guy and say hi! :) I'll probably have a radio on me listening in to what's going on in the plant as well.
