Pro 106 programming question...
TheCosmicCowboy
Poteau, OK
Hello. Have a Pro 106. Haven't used it in a while. I programmed it shortly after I purchased it (late 2012). Used the ARC 500 & cable that was purchased from Radion Shack. A few days ago I got it out and tried to update it. I purchased a subscription to this site as well as the ARC 500. I can't get it to work. Any suggestions and/or tips are welcome. Thanks!
ecps92
Taxachusetts
what exactly is not able to work ?
Software reporting an error ? What error
RoninJoliet
ILL
The RS 106 is extremely easy to pgm by hand also , for a trunk system a few key strokes gets you a wildcard ,...
Ronaldski
MI DB Admin
Bay City MI
Make sure the cable is all the way in. Ive programmed a lot of those and desktops, sometimes it wont work. When it happens I push in the cable on the radio, I bet a mere 1/64th in and it always works.
I dont use arc500, but psredit500. In the settings on that I use "Direct" to connect and not having to mess with Com ports.
Check the setting in your software. PSREdit does have an option to convert from ARC500 files if you wanted to try that and has a 30 day free trial.
tvengr
Well Known Member
Baltimore County, MD
Is the correct cable driver installed? Windows updates can cause problems. ARC500 has a generic driver installer which works with Radio Shack cables. In ARC500, go to the Scanner tab and click on Install USB driver.
TheCosmicCowboy
Poteau, OK
First of all, I would like to thank all that replied. Much appreciated. Thank y'all very much. I'm using the 20-456 cable. One end is plugged into the USB port of the computer (I have a Dell laptop). The other end is plugged into the pc/if port. Both connections are snug. After several attempts, I think the problem may be the USB port number. What number should I be using?
I will try to program by hand. I'm trying to update the OK-WIN for Oklahoma, and AWIN from Arkansas.
Engine104
Member since 2005
Winnetka, CA
I think you just have to try using each of the ports listed in the program until you find the one that works. That's what I had to do with my ARC-96 and ARC-160 programs.
