PRO 106 speaker
I found out that the PRO106 ear jack is different than other scanners for external speakers., What is the BEST speaker to use with the PRO106 ear jack to amplify the sound ?
HopperD
Los Angeles
I just bought an external speaker from Radio Shack and it works pretty well.
Here is the number: CAT. NO 21-131
I also have an Auvio blue tooth speaker that I use sometimes but I plug it in with the AUX wire.
Here's the number for this one: CAT. NO 4000375
Hope this helps you out.
kc4jgc
Virginia Beach, VA
Wirelessly posted (BlackBerry8320/4.5.0.81 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/100)
Because the intended use is for either an earplug or headset, the audio level is intentionally lower than the level coming out the speaker. An amplified speaker may work best depending on you monitoring situation. If you're in your car and you have an auxiliary input jack on your broadcast radio, you can send the audio to your car speakers. That should be enough amplification for you.
Swipesy
Northern Ohio
I don't know if it works with the Pro 106 but it does with the GRE PSR 500. Take a thin wire and wrap it around the antenna post. Wrap the other end around a non amplified speaker's cable input post and plug it into the radio's headphone jack. This defeats the low volume facor and then a non amplified speaker works perfect. Been using this for 8 years on the 500 without an issue.
Ensnared
Waco, Texas
Best Speaker
Since "best speaker" was used in this thread, I believe this speaker might deserve a review. I believe it works with scanners. Yes, it is a bit pricey, but I've heard some people love them. Gap HEAR IT dsp speaker Product Reviews
I prefer routing my PSR 500 into my MP3 jack on my Kenwood. Nothing sounds like a scanner running through 600+ JBL watts.
external speaker
WOW, thanks for all the reply's & support . We will see what happens.
Ensnared
Waco, Texas
Best Earphone
Also, I strongly recommend the following mono earphone for your radio. Since the Pro-106 tends to have a lower volume when compared with the GRE version, some people activate the "audio boost" on the radio. If you are using Win500, it is near the the area where you adjust the alarms & LED behavior.
If I'm not piping my radio into my stereo, like on trips with my wife, I use two of these earplugs, one for the scanner & one for the CB. Amazon.com: Accessories Unlimited AUEPD1 Earphone With 3.5Mm Plug: Cell Phones & Accessories
You used to be able to find these at most truck stops, but for some reason, they are hard to find.
I have a professional grade earphone like the ones LE uses with the clear spiral cord, fits inside the ear canal. While it delivers a solid sound, it is still diminished when compared with the aforementioned earphone. The earphone I recommended is positioned over the ear canal instead of inside. It uses a fairly large speaker as well.
