Pro-106 Stalker Delay Problem
Forts
Ontario, Canada
Anyone else seeing this? While using the Signal Stalker on my Pro-106, the Delay option doesn't seem to have any effect. Delay is turned on (as indicated on the display by the 'D' vs 'd'). When the Stalker stops on a hit, it immediately starts searching again as soon as the transmission is complete. On a quick hit I can hardly get a look at the display before it goes on it's way again. I see there are some Stalker settings/delay times that can be fiddled with in PSREdit/Win500.... Any recommended settings there?
My 197 seems to do the same thing, all I know to do is set the delay longer. Someone else may have a better idea...also omly had my radio about 3 weeks:). Using the above software same as you. mainly PSR edit tho.
Paul
DonS
Franktown, CO
It's likely "Zeromatic" hitting. That feature tries to look for the "real" frequency when searching (including Stalker). At the end of the transmission, it's possible that the hardware is thinking the actual frequency is one step up/down.
To test it, turn ZM off via FUNC 0 (zero)
Forts
Ontario, Canada
I think that may have done the trick, from what I'm seeing so far. Thanks very much for the tip Don! I wouldn't have even considered zeromatic settings in this situation.
