Pro-106 Two Questions.....
Tramagod
Killeen,Texas
I have two questions about Pro-106 Programming. I recently purchased a used pro 106 that came with a usb cable, (part# 20-047) which has a list of scanners that it should work with, and a list of scanners that it will not work with. The Pro106 is not on either list. Is this the proper USB cable? My second question si, I did attach the cable to my PC, it did download and install the drivers, but it doesn't appear to be working. I've tried it with the 3 inch cable and without. Any pointers there would be appreciated. Thanks in advance to any useful information.
Ronaldski
MI DB Admin
Bay City MI
Go into device manager under ports, remove/uninstall the port.
Now use the included cd to install the correct driver. Many times windows on programming cables install the wrong driver.
Then & only then after the cd drivers are installed, plug in the cable.
Dont use the cable attachment for the 106.
