Pro 106
DOGGY1
BRANTFORD,ONTARIO
HI,everything goes good till I get down where I type in mot vhf/uhf and then when I get to tag mine says system instead of wildcard,when I continue on nowhere does it say wildcard and when I finish up sometimes it says talk group unsaved changes.I will try it again a couple of times again tomorrow,as I must still be doing something wrong
Thanks Dan
Thanks for expert help,I don't know what I did but I finally got it working with the wildcard like you said.It receives both the opp and the ambulance calls,digit and analog.Can you tell me how to save this set-up to one of the v folders as I am afraid I will lose it some how.
Again thanks again for your help Dan
Forts
Ontario, Canada
V-Folders are super easy. Just hit FUNC then PGM. Then you should have 3 options I think (I don't have the radio in front of me) Load, Save and Exit (or Cancel maybe). Use the Up/Down buttons to select the slot you want to save in (It should be on 1 by default) then just hit Save... it will give you the chance to change the name of the V-Folder if you choose... then it should save the file. Scan will get you back out. Should you somehow mess things up and you want to revert back to what you had... same steps. FUNC-PGM, then hit Load instead of Save.
Glad you are having some success!
DOGGY1
BRANTFORD,ONTARIO
Thanks again for you help in getting this radio going,I don't I would of gotten awaywhere on my own.Now that I know this radio works fine,I will look int getting the programing cable and a program to make my life easier.Do you have a number for the cable and a good program and where I might purchase them?
Thnanks Dan
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Thnanks Dan
This would be the cable you need. RadioShack® USB-PC Interface Cable for GRE Scanner - RadioShack.com
Best bet is to head to the States and pick one up.
unlisted
Western Canada
Also FYI re the programming cable- if you can wait, just watch the Radioshack website- they go on sale for half price every now and then.. ;)
DOGGY1
BRANTFORD,ONTARIO
Hi,we don't have radioshack in Canada anymore,would the Source carry them?.
Thanks Dan
unlisted
Western Canada
we normally talk "American" re: RadioShack since the Canadian "Source" sucks for scanners and accessories. AFAIK, The Source does not sell those programming cables.
If you cannot get across the border, best to post a "wanted" ad for one in the classified section of this website.
DOGGY1
BRANTFORD,ONTARIO
Ok,thanks for the info
Dan
VE3JSO
sarnia ont
the source does have the pc if cable for the scanner but is around 89.99 saw it on there web site
VE3JSO
sarnia ont
yea i picked one up when i bought the scanner my last post was to a prev post :p
