PRO-163 viper help
KE4ZNR
Radio Geek
I need some help in programming this scanner for the nc viper. Can someone help?
I have some unfortunate news for you as the Pro-163 is an analog voice only scanner and VIPER operates in a mostly digital voice format which means your monitoring capability of the system will be extremely limited.
Marshall KE4ZNR
drayd48
thank you. I will just trash the scanner. I have no use for it. Thank you again.
don't do that. It could be used for many other things. Thats about one of the most saddest things i have ever heard
buddrousa
Yes do not do that that scanner would work for several users here in the forums you could get a fair price if it is in good shape between $50 to $100 if you list it in the classifieds. That would go toward a scanner that would fit your needs.
