Pro 163
scottlattin
Texas
I'm sorry but I am really new at this and I couldn't figure out how to start a new thread
Hello: I just received my RS pro-163 and I must say that as a first scanner...IT IS AWSOME..
With that said, HELP. I have sucessfully programmed my scanner using the software but now I have to figure out an ant. for my patrol vehicle. I do not, nor can I, use an ant. that it for ever long. I was thinking about a one of those really low profile disk type ant. but I need to pick up multiple freq.
I work in Dallas and Richardson Texas but I live in Fort worth. While I was at home I was able to hear Dallas broadcast but at work I cannot hear Fort Worth.
Any suggestions??
hiegtx
Dallas, TX
Any suggestions??
Scott,
Depending on exactly where you work in the Dallas/Richardson area, reception of the Fort Wort/Tarrant County system is going to be sporadic at best. The key is distance and elevation. You're right near the ragged edge of best possible range. In my vehicle, I can occasionally hear Fort Worth while sitting in the parking lot outside my office location (near Forest & Central, just west of Medical City), but the lot I'm in is on a slight hill. Once I'm off that point, no more Ft. Worth.
The 800mhz signals don't travel as well, so to speak, as the Uhf signals used by Dallas PD/FD. The 800mhz band is much more 'line of sight'. I can generally hear Dallas out into eastern Parker County. Some of the stronger Vhf-high agencies (an even lower frequency) may be readable even farther.
Is the Pro-163 mounted in the vehicle, and you want to mount an external antenna on it? Or were you leaning toward a magnetic mount, that can easily be removed when not in use. You'll probably get a wider range of suggestions in the antenna forum. Also, the Pro-163 has a fairly "hot" receiver, meaning it's very sensitive. That can be good, but also has it's drawbacks. Nearby transmitters, such as cell towers, can overload the scanner's front end, causing it to desense, and actually become less sensitive. One way to combat that is by using the attenuator function. As an experiment, you might 'copy' your Fort Worth programming to another bank, but set attenuation for that bank only, and see if you can then notice any difference. Note that adding an external antenna will increase the signal to the scanner, but also increase the possibility of overload, if you have a number of cell sites in the are you're using it in. For my PSR-500, a digital scanner made by GRE (the same company who made the Pro-163 for Radio Shack), using a gain antenna caused it to overload & hear less. I have a virtual forest of cell towers in and around my neighborhood. I ended up using the stock antenna around town, only switching to a gain when I'm out of the metro area, and clear of the heavy rf interference.
scottlattin
Texas
Helping a Newbie
Steve: Thanks for the advise. I work at two properties, Coit and Beltline and south of 75 near Arapaho.
I will try the forum you suggested, I do take the scanner out every night and there is a mounted antenna approximately 6 to 8" from a uniden 350c that burned out. I would prefer something a little more professional for our patrol vehicles that's why I thought about the flush mount variety. Again thank you
Best Regards
Scott
Son Of KA5ZCV
RIP Dad.
fuzzywuzzy1
Central Florida
Hey Scott, I too just purchased a RS Pro 163 and have no idea on how to program it. I live in Brevard Co. FL. From what I understand Brevard Co. FL law enforcement agencies operate on 800 trunk ystem and someone said it's an EDAC(?) Can you please help me with programming my scanner? I did figure out how to manually enter some frequencies that I found on line, but very limited. I then found some additional frequencies but were not in the traditional format. They were in DEC/HEX form which I totally don't understand. Anyway, any help would be appreciated!!
hiegtx
Dallas, TX
Best Regards
Scott
Son Of KA5ZCV
RIP Dad.
Scott,
If that "mounted antenna" is for your vehicle radio (2-way transmissions), be sure & get as much separation as you can, between whatever scanner antenna you decide on, and that mounted antenna. The high power even if the scanner is not programmed for the frequency) can damage the front end of the scanner.
South Central Minnesota
Go here...Statewide Law Enforcement Radio System Trunking System, Statewide, Florida - Scanner Frequencies
Figure out which site(s) you are closest to then follow that row to the right to get the frequencies for that site. Freqs in Red are Primary Control Channels and Blue are Alternate control channels. Read your manual or the online manual to find out how to put in an EDACS system. Here is the link to the online manual, start at page 35 to figure out how to program a trunking bank. http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000163_PM_EN.pdf
ST-Bob
Worcester, MA, USA
Remember that EDACS trunked systems must start at channel X01 (001, 101, 201 etc.) in any bank rather than at x00 like conventional frequencies. You can mix EDACS and conventional frequencies within a bank but you cannot mix different trunked systems - 1 per bank in other words.
IronEagle31
Homer, NY 13077
I have a Pro 163
I have a Pro 163 Scanner and I love it very much and I will always Continue to use it as long as it stay's working and I sure hope that this Scanner stay's working for a very long time to come
scottlattin
Texas
help programming
I wil be glad to help you in any way that I can. What I will do is go through the steps of programming your area on my system and have my wife transcribe it in an email:)
