Pro-164: Pro-164 manual stepping
scanmanmi
Central Michigan
I've only got a few freqs in an bank but when I scroll up or down it goes through the unused 87 channels before it gets to the next bank. I've checked the Lockout in the software to no avail.
wtp
Port Charlotte FL
did you try
turn the squelch off and hit scan ?
i think you meant to get to the next used channel.
dispatch235
Central Missouri
That is normal for this scanner, and most scanners when scrolling manually ... lockout only works for scan mode
gmclam
Fair Oaks, CA
Agreed. Otherwise, how would you navigate to a specific (unprogrammed) channel so you can program it? You should also realize that you can (while in MAN mode), press the 3 digit value of the channel slot, then press MAN, and go directly to that channel. For example: 0 0 0 MAN will take you to the first slot.
