Pro 197 Led Lights
LH2428
Florida
I was wondering if any of you guys had some cool HEX color codes for the pro 197?? I know you can edit and create your own colors for alerts on the pro 197
gmclam
Fair Oaks, CA
GRE multi-color LED
I've found that, other than primary colors, there are vast differences from scanner to scanner. I had one scanner that would display yellow beautifully, but that same code on another scanner looked terrible. I couldn't get yellow to ever look good on the second scanner.
I'm fairly happy with the 16 color combinations provided, which includes no light to white and flashing or solid. When colors don't work like yellow, then I've programmed pink (useful for medical channels) and gray (several shades).
jfhtm350
New Market TN
I was about to say the same thing as gmclam. I programmed a few of my own in there and they didnt even look close to what it was suppposed to. I just stuck with the original colors. You could bring up Paint and create a custom color and copy the hex codes over and check it out.
fxdscon
¯\_(ツ)_/¯
I'll second that. I have 3 Psr600's stacked up, and any chosen custom color, and even some of the primary colors will vary greatly between the units.
