Pro-2067 Trunking Programming
bamafever86
Tallahassee, Florida
I have a Pro-2067 I am trying to program Motorola Type II System into it. I cant seem to program this thing correctly. Can anyone give me some pointers or tips on programming this thing? I am programming 800 mhz trunking channels.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
What system are you trying to program? Go up to the blue toolbar on the left under the site title and float your mouse over database Use the pulldowns to get to your desired system.
and this might help...
Programming Shortcut Pro-2067 - The RadioReference Wiki
Note that if the system has any digital talkgroups the 2067 won't hear them. Nor will it hear any system where all the talkgroups are digital. You can tell this by the mode column - digital tgs are always indicated with a 'D'. An 'E' is an encrypted talkgroup and nothing will decode them...
best regards..Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Ignore the map stuff - you don't need it for that system. best regards..Mike
N8IAA
Fortunately, GA
Thanks for your help. I just dont understand the map stuff. This is the system i am trying to program.
Tallahassee / Leon County Trunking System, Tallahassee, Florida - Scanner Frequencies
Bamafever86, you'll have to put in all frequencies listed in the database for the 2067. The only problem may be that some of the frequencies may change value. If this is the case, the 2067 will not properly follow the system. You will need to upgrade to a newer scanner to TT the system. Make sure that when you program, you go to the bank that you want the system in and make sure all the frequencies and TGID's you want to monitor are in MOT mode.
HTH,
Larry
bamafever86
Thanks Larry for the info. I have one more question! When I enter the freq. into the bank....Do I then program the "DEX ID's" into the trunk side? I am still confused. I have done this and get nothing. I am at a loss on how to program this thing. If anyone can help please give me a shout!
N8IAA
Fortunately, GA
It's literally been over 7 years since programming one for a friend where I used to work. I believe pressing Func, then Trunk while in the bank allows you to program the TGID's. I'm sure someone will jump in with the correct proceedure:)
Larry
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I think you meant 'HEX' not 'DEX' - anyway you should ignore the hex IDs in the database - some of the Uniden and GRE/RS models can use these (as can all the professional models), but the older scanners can't. Just use the ones in decimal
best regards..Mike
TEH
Central Florida
Pro 2067 programming
Hello from Central Florida,
The Leon County-Tallahassee trunk system apparently uses digital modulation, and does not appear to be compatible with your Pro-2067 scanner.
Here's the Radio Reference database for the digital system:
Tallahassee / Leon County (Project 25) Trunking System, Tallahassee , Florida - Scanner Frequencies
The wiki page indicates the analog system is no longer in use.
Tallahassee / Leon County (Project 25) - The RadioReference Wiki
Here's the Radio Reference database for the perhaps no longer used analog system:
I'm not within range of Leon County, so I can't monitor it. But I recall years ago that the city & county launched a digital trunk system.
hope this helps
