a. P25 Missouri Statewide Inter from transmitters in Boonville, MO
b. Discone up 20 ft., located 3 miles from tower.
c. RC500 1.16 build 1/RS - Full Version
d. Signal strength is excellent. I read a post about turning attenuator on. Will try that, since I'm so close to the tower..
e. I have not adjusted VR4
f. Frequencies are in the 154-158 range, so band is no problem.
Thanks. 73.
You need to program extended table info in order for the Pro-2096 or Pro-96 to receive the VHF Moswin sites.
These old models cannot get that info from the control channel like your 106 can.
Here are some screenshots from Win 96 that show the extended table needed.
This has been in my Pro-96 for some time but I believe the info is still correct.
There is a thread somewhere here for this and maybe something in the Wiki also that explains the tables needed in these models for Moswin.
I'd try and find that thread or info as they may have added one more table line for some sites but I believe just the 5 lines in the 2nd screenshot are all that is needed for Moswin's VHF sites.
I know you need software to enter this data as it cannot be entered via the scanners keypad.
You also said you are using ARC500. That software will not work for the Pro-2096. It will only work for your Pro-106.
You need either WIN96 from starrsoft or ARC-96 from Butel to program your 2096 model.
You need to set the Mot 9600 CC to Multi Table as shown in the 1st pic and then click the Extended Tables button and enter the 5 lines of the custom (extended) table info from the 2nd picture.
I don't know how or where to enter the extended table info in ARC-96 but the info should be the same once you find the spot in your Arc software (assuming you do have ARC-96).
My screenshots are from Win96 as I never purchased Butel's ARC96.
