Pro-60 Battery Holder
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Does anyone know where i can buy a new battery holder for the pro-60 it is the one that take 6 AA's When i put it in the scanner won't power up but when i first bought it off eBay it worked fine.
Caesar
Lexington, SC
do you see anything wrong with the battery holder or any damage to it for why it might not work? does the radio still work if you plug power into the side of the radio?
w4esp
Green Cove Springs, FL
battery holder pro-60
for the pro-60 battery holder try radio shack, or there repair centers, the part number is hb1081 i beleive
Bentley
Freehold, NJ (Monmouth County)
***GENTLY*** try to bend the contacts or springs forward (outward) so they get good contact with the scanner. Or , again GENTLY, try to bend the contacts on the scanner forward. Maybe that will help? Those holders typically don't go bad...there is not too much that can go wrong with them. But the metal contacts can bend inward if they are old, causing a "miss" when they are inserted.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Yes it still works when plugged into a power source but it won't work when i put the battery holder in and i tried the bending the battery prongs and it did no good still won't come on does rs have this holder?
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Bentley said:
They should be able to order it for you. Or call the toll free number.
Well i called my 2 local stores and they both said that they don't have any in stock at the ware house where else can i get a pack i really would like to be able to use my pro-60 again without having to plug it into a power source.
Bentley
Call the RS parts number directly, 1-800-843-7422.
The item number you are looking for should be as follows:
Cat No. 10657013
Description: HOLDER,BATTERY CASE
NP Part No. HB1081
KC5EIB
Flower Mound, TX
Go to your local Radio Shack, The sales person needs to go to the POS, RSU Transactions and order Part Number 10657013, $4.99 In Stock
Nasby
Ohio
Go to the Radio Shack at Walmart plaza on SR 59 in Ravenna. Ask for Brett Hoover the manager. He is very knowledgeable.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Hey thanks i'll do that!
