pro 651
wheelhorse1968
im trying to program a new 651 scanner and keep getting nothing enabled message and I cant figure it out.i would appreciate if anyone has run into this before and could tell me what im doing wrong.thanks
ecps92
Taxachusetts
Did you enable the Scan List for what you programmed ??
N8IAA
Fortunately, GA
Depending on your software, to enable a scan list/lists, on the main page place a check mark in the box next to the system/systems you want to monitor.
Or, press the number keys from 1-0. It will do the same thing.
Larry
wheelhorse1968
i think that's my problem,i cant figure out how to enable the list i downloaded
wheelhorse1968
enable list
ithink that is my problem,i cant figure out how to enable it.cant find it in manual.and it is a radio shack pro651 by the way . thanks in advance for any info you can give me. jon
TAbirdman
MO
When you turn it on and after the welcome screen finishes does the unit show "SCANNING" with either dots or numbers below it? You have pressed the "SCAN" button correct?
The default scan list is #1, is number 1 showing on the screen? If not what numbers are showing?
DJ11DLN
Mudhole, IN
This tripped me when I first got my 197 (same radio), it's sort of in the "too simple" category. Just press the number of the scan list you put your stuff in. That enables it. Press the number again to disable. I spent a couple of hours wrangling with it before I stumbled across the answer. Big facepalm!:roll:
wheelhorse1968
well it says its scanning and the 1 is the only number on.i put all channels on 1. I don't know what I did but I got one channel to pick up but its not receiving anything else.this is a lot different than the pro 96.
wheelhorse1968
well its only picking up like 1 talk group my pro 97 is still pickikn up stuff this one isn'i don't know ill get it figured out lol thanks alott.
TAbirdman
MO
Under where it displays "NOTHING ENABLED" you have two rows of dots correct? If so, simply press 1 if you want Scan List 1 turned on, press 2 for scan list 2, etc..
