naaaaaathan
- Joined
- May 24, 2004
- Messages
- 7
Hello Everyone
I just had some questions for those that listen to ATC/Aviation frequencies in their respected cities...
I live in the Northside Of Houston and currently have a Radio Shack Pro-89 Scanner with a Center-Loaded Telescoping Whip Antenna (9 Sections) about 2 ft. I get clear reception ONLY when I am at or close to the ATC tower at IAH. My problem is that I get very, very noisy and fuzzy transmissions. I live about 20 miles away from the airport and would like to listen at home without all this noise. If I am lucky I can hear bits and pieces of the ATC and Pilots but most often it is really noisy..
For those that listen to ATC/Aviation frequencies at home is there a particular antenna and location that is best to get clear reception??? Is the Center-Loaded Telescoping Whip Antenna good to be using?? Or is there any other equipment (Scanner, Antenna Etc) that would be recommended by anyone to get a good reception??
Thank You All
--Nathan
Thank You All
--Nathan
