pro-92b trunking problems help please
radioscan
Radio Sensei
Southern Ohio
Make sure the LCN order is exact, do not start with a Channel 00 memory slot and the bank and channels are set for EDACS wide.
LCN-1 851.1000 = Goes in a Channel 1 slot
LCN-2 851.8875 = Goes in a Channel 2 slot
LCN-3 852.3875 = Goes in a Channel 3 slot
LCN-4 852.9125 = Goes in a Channel 4 slot
LCN-5 853.4625 = Goes in a Channel 5 slot
LCN-6 851.7125 = Goes in a Channel 6 slot
LCN-7 852.6750 = Goes in a Channel 7 slot
bigbud42010
Springfield, Ohio
well i kno wat im doing cuz i fixed my problem it wont trunk channels right for sum reason and yes they r in lcn order i have to have them in am or fm not ed ltr mot pl or dpl mode idk wats wrong
radioscan
Radio Sensei
Southern Ohio
Springfield LCN Correction
WS Electronics apparently did the same thing they did when rebanding the Clinton County system. They left the old frequencies in to make sure the radios that have not yet been reprogrammed will continue working. Here is the corrected LCN order and I have made the changes to the database listing;
LCN-1 866.1000 dead
LCN-2 866.8875 dead
LCN-3 867.3875 dead
LCN-4 868.4625 dead
LCN-5 868.7125 dead
LCN-6 866.7125 dead
LCN-7 867.6750 dead
LCN-8 853.4875 talkaround
LCN-9 851.1000 active control channel
LCN-10 851.7125 active
LCN-11 851.3875 active
LCN-12 852.9125 active
LCN-13 851.8875 active
LCN-14 852.6750 active
LCN-15 853.4625 active
They have also added three more Citywide talkgroups that have also been added to the database;
1573 Citywide- 5
1574 Citywide- 6
1575 Citywide- 7
Give it a try with this correction and let us know how it works.
wa8pyr
Lead Database Admin
Ohio
Well, I think I know what you're asking, so I'll give it a shot:
they r in lcn order
Correct. They have to be in LCN order starting with 01, not 00.
It should default to FM. AM is not correct.
if you're trying to listen to an EDACS system, ED. For an LTR system, LTR. For a Motorola system, MOT. PL and DPL are for conventional frequencies only and do not apply for a trunked system.
radioscan
Radio Sensei
Southern Ohio
Myself, and I'm sure everyone else on the board would appreciate it if you could type a little better so its more coherent and not like you are texting.
Or at least use a spell checker...
Thank you,
andyishere
Ohio
It works fine for me except for some random burst of encryptio maybe? Thats what it sounds like, may be wrong! I have it i FM and receive just fine other than that. Don't know whats wrong with his. And I keep hearing Fire Department. Medic 51, Engine 35...
bigbud42010
Springfield, Ohio
well my scanner took a crap cuz i was messing with the insides and turned a magnetic screw and screwed the Fm and all modes except am and thats what i receive the city on and so im getting a pro-164 i do beleive next week i already got a bnc to coax connector today so yea ill ask for guys help next week
hey andy thats was i getting on my scanner i heard engine 51 and medic 51 i dont know what that was
andyishere
Ohio
Ah, I have a Pro-164. So I am tryig to figure out what the Medica 51/Engine 51 is. I know Spfld Fire Rescue has a Truck(ladder)/Medic Five, also I've heard several Medics say that they are out Of Springfield Regional Medical Center(Community)
radioscan
Radio Sensei
Southern Ohio
What are you guys hearing "Medic 51/Engine 51 on?
Springfield system Talkgroup or on a conventional frequency?
bigbud42010
Springfield, Ohio
more likely well ive made my mind up im getting a pro-163 base reviews are good so im getting it my b-day is next week so i was gonna get the pro-164 but i dont wanna buy a adaptor
andyishere
Ohio
Okay, are you buying an antenna for it or using the one already with it?
radioscan
Radio Sensei
Southern Ohio
LCN order has been corrected once again:
Code:
01   866.10000
02   866.88750
03   867.38750
04   868.46250
05   868.71250
06   866.71250
07   867.67500
08   853.48750
09   851.10000d
10   851.71250
11   852.38750
12   852.91250
13   851.88750
14   852.67500
15   853.46250
bigbud42010
Springfield, Ohio
ok i wanna program this scanner for xenia im a county up from them an i can pick up there beavercreek 860.6375 tower now how would i program that so i can get it
radioscan
Radio Sensei
Southern Ohio
What? 860.6375 is their SCAT site in Springfield, not Beavercreek.
That SCAT site is there solely for the business users on the system when they have to be in that area.
Still if you want to program it in, you use only that frequency in a bank programmed into a Channel 1 slot and set it to EDACS.
