Medic32 said:
Does anyone else have a Radioshack PRO 95? If so can you tell me how to block out TG's in a trunking bank?
Beginning at the bottom of page 65 in the pdf owner's manual:
"LOCKING OUT TALK
GROUP IDS
1. Press PGM.
2. Press TRUNK.
3. Press FUNC /\ or \/ to
move to the desired bank.
4. Press /\ or \/ to select the
ID memory.
5. Press L/OUT to lock out the
ID. L appears.
6. To remove the lockout from a
trunking ID, manually select
the ID memory, and press
L/OUT until L disappears.
You can confirm the ID code while
the scanner shows the text when
the received signal is a voice
channel.
1. Press TEXT while the scanner
is receiving the voice channel
and indicating the text name.
The ID code appears as
MOT:XXXXXX or ED:XXXX.
2. Press TEXT again to cancel."
