Pro-95 ....
derrek_lee_25 said:
how do you lock out talk group ids all i want to hear is police and fire and i tried hitting the l/out button when a non police and fire id came up but it didnt work
In reading through the posts here, the instructions seem a bit confusing. So I feel a recap is needed for clarification.
1. Since you are asking about "talk groups", a trunked system is assumed. The bank which contains the trunked system must first be closed. While scanning a "-" will appear under the bank number if it is closed. If a "+" appears under the bank number, go to manual mode, navigate to the bank (any channel) and press FUNC 5. A message should briefly display indicating that the bank has been closed.
2. With a closed bank, only programmed, non-locked-out talkgroups with its associated sub group turned on will be heard. If only police and fire talkgroups are programmed, you're in biz.
3. But your original question was how to lock out talk groups. So perhaps you're past all of the above, and you still want to lock out something you've programmed. While a talkgroup is talking you can press L_OUT to lock it out. Otherwise to toggle the lockout status of a talkgroup; go to manual mode, navigate to the bank, press FUNC TRUNK, navigate to the talkgroup. Now you can press L_OUT to toggle the status of that talkgroup. An "L" will display when the talkgroup is locked out.
Good luck
